Let me preface this post by saying that I'm totally ok without remote start, which is mostly a waste of gas in my opinion.
I wouldn't mind having remote door locks; however, since purchase I've always used my key.
The previous owner had a "Directed" DS4+ with Viper 4-button remotes installed. It's either not a good system, or the installations wasn't well done:
A. It uses an estimated crank time (virtual tach), so sometimes it doesn't start, and other times the starter keeps running even after the engine is running.
B. It always honks when locking and unlocking, which I find tremendously annoying.
Now...to the problem: I suppose I did exactly what you're not supposed to do with these systems and attempted to reprogram it, hoping that I could get rid of the honks and reset that virtual tach. Long story short, I messed up the programming entirely. I hoped that I could save it by disconnecting the battery, but that made it worse. So this is where we are:
Yes, a complete mess!
On a side note, I opened the fuse compartment on the brain, and there actually was a blown fuse; however, replacing it with a new fuse had no effect.
Now my question: is there anyone here who can make a recommendation how to fix this myself? Or anyone in the Richmond, VA area who could help me? I'll buy you a coffee.
I know I can take it in to have it reprogrammed, but honestly it's not even worth it to me. I can just use my key old-school.
- pressing lock/unlock does produce the normal parking light flashes and honks but the door locks do not do anything
- pressing the trunk button opens the trunk AND simultaneously locks the doors
- pressing the start button unlocks the doors and cranks the engine, and the starter keeps running until you cut if off by pressing the button again
