I just did a search and I found nothing.
I just removed my V8 emblems off of my 95' bird, put it out in the sun and the paint matches fine. Can't even see it.
I really want to remove the door moldings also, but I'm afraid the paint might be faded. The car was never re-painted and grage kept. Should I be in the clear?
Thanks.
most of the time you can use a heat gun while yur trying to pull the moldings off and they come off fairly easy. the double sided tape behind the moulding you can take off with a pintstripe eraser you can get it at almost any parts store, it just hooks into a drill but you have to be careful and not stay in 1 spot too long or you'll burn through the paint, other than that you should be fine if the car still has the original paint. good luck:thumbsup:
11pm and half of the car is done.... I hand polished my car last week,
I took the buffing wheel to remove adhesive on my door with rubbing compund and some wax. urge to do the whole car again lol its glass.
other half tommrow... it looks good!
