Like the title says, how do you remove the door panels and rear speaker covers off of a 97 cougar? I remember on my 93 it was fairly easy, but in the newer interiors im lost. Thanks!
Just a quick question. How hard should you have to pull up on them to get them off? I took the 2 bolts out and it seemed like it was still stuck on by something. Could it be sealed to the door somehow?
you have to take out the screw behind light panel.
then pop the window switch panel theres a screw there. undo the switches wiring harness. unscrew off the door lock knob if you have the dice or other custom ones cause they won't fit through the door panel hole. The window switch panel pops of but it slides forward to get it past the door handle.
