· Registered
What is the best solvent to use to remove undercoating?? I have some clearish looking stuff (It might be a rustproofing stuff-it really doesn't look like undercoating)on the flat surfaces under the hood around the engine compartment--I'd like to remove it w/o taking the paint off--I am trying to use Gunk Bug and tar remover--it works but I think there must be something a little stronger???? Thanks!!
· Registered
Discussion Starter · #4 ·
I guess I should clairify that what I was trying to remove is in fact rustproofing and not undercoating from some areas in the engine compartment--I ended up using the mineral spirits and it worked great followed up with Greased Lightening cleaner then my Liquid glass polish, looks good now!! Thanks!
