I'm just curious as to everyone else's "experiences"... :D
What is the most money you have spent to "fix" a problem, when the "actual" repair was considerably less expensive? :2huh:
I'll start... :leftright
Vehicle: 65 Mustang
Problem: Every time I would take a hard left turn I would have a tire rub a fender. Right turns did not have the symptom.
Money spend repairing: $350 to rebuild a front suspension
Actual cost to repair problem: $1.50 to put fluid in the power steering reservoir.
The low fluid was sloshing to the side of the reservoir and the pump was sucking air.... sounded just like a tire rubbing... :redmad:
Go ahead and fess up, I know we've all had experiences like that!!! :thumbsup:
Vehicle: 89 Cougar
Problem: rough idle, wouldn't rev out, tranny shifting erratically
Money Spent: 5,500 on 97 Cougar
Actual cost: 8 dollars in spark plugs
On the other hand I now have an 8 year newer car with a V8 and still have the 89.
1994 explorer
problem: every time I hit a pot hole I would get a loud clanging noise (sounded like bad ball joints/ or broken spirng), after replacing the ball joints (which were only a little warn) checked the springs.
Money spent: new upper lower ball joints both sides don't remember exactly but it wasn't cheap.
actual cost: .72$ I had a missing screw that secures the metal headlight gaurd so when I hit a pot hole it would bounce against the rest of the grill gaurd...
motor city poster
Damn im gonna burnt for this...
96 bird...
had a rattle in the front suspension....
strut rod bushings-
strut mounts-
sway bar end links--
actual problem.... F'n top shock to mount nut was loose...grrr..
I replaced the entire Multifunction switch because only the high beams worked. Low beams did not. Since the low beams went out simultaneously I knew it couldn't be the bulbs. After buying the switch, taking the steering column apart, and installing a new one, I found out that it IS possible for BOTH bulbs to blow at the same time.
