Finally had an upper ball joint wear out at 205,000 miles.
Driver's side had about 1/8" of side to side play in it.
Glad to see the new motorcraft ones have a grease fitting.
Tools needed;
Trolley jack, and one jack stand.
18mm 6 point combination wrench.
18mm Craftsman ratcheting combination wrench.
Torque wrench.
Torch - to heat up the upper spindle arm.
Lots of brute strength....lol
Worst part of job for me. Separating the ball joint stud out of the upper spindle arm.
Amateur Expert
Last weekend I started to disassemble the suspension in anticipation of our GP lowering springs. The rear springs came right out after a few bolts were removed. The right front spring/shock assembly also was cake. The left front we had to wrestle with the upper spindle like you did and the worst part - I cannot get the lower shock bolt out of the lower control arm bushing. The nut is off, it turns, it just won't come out!
I haven't removed a lower shock bolt before, but if you search thru the forums, someone posted the details on getting that out. I think there is a split steel sleeve around the bolt. Corrossion probably 'fuses' the three together (control arm, bolt, sleeve)
