I was recently poking around under my LS, and noticed that there are no U-joints connecting the driveshaft to the rear end gear pod.
Check out this pic:
The driveshaft bolts directly to a chunk of rubber about 3/4" thick, which then bolts to the rear end gear pod. Didn't look at how the driveshaft bolts up with the tranny, probably is the same thing.
Is this a dumb/bad idea, or is it a better one to get around using U-joints on IRS applications where the rear end is fixed to the body?
It's too late for me to adapt this style connection on my Cougar after making a custom driveshaft, but it got me thinking about it.
Don't quote me on this, but I think I once read that a U-joint needs at least 2 - 3 degrees of "miss-alignment" to function properly. It has to do with the “rolling” of the needle bearings in the U-joint. So on an IRS setup where everything is aligned, a coupling might be more appropriate.
I don’t think it would really matter that much unless the rest of the drive train moves around a whole lot. But I would also bet that it’s there to reduce vibration and harshness and not for a “better” design. It is an LS after all… supposed to be smooooooooooth… :thumbsup:
And with all the new technologies in compounds today, that “rubber” piece may be stronger than a u-joint setup.
But it is interesting. :D
Just my .02. :thumbsup:
Good points there, it just surprised me to see a rubber disk connecting it like that.
Can't imagine it'd last for 20 years, but then again - what U-joint would, and would replacing that rubber disk be all that expensive?
We'll probably see alot more crazy stuff in the coming years on cars. Like plastic wheels :eek:.
