Just wondering if it really resets the engine computer and clears check engine codes by pulling fuse 15 and then trying to start car or should the neg. batt. terminal be removed for a short while?
Yep, that's the one.
As far as I know you can either pull the fuse and try starting the car or just pull the fuse and wait awhile. I guess it depends on what you are doing at the time and how quick you want it done.
Speaking of that...
I saw an OBD II code reader at Cosco the other day...
Is that what I need to be able to read codes and clear them for my 94?
It was fairly cheap at $35.00
If not... the intarweb is your friend. :)
