I know the '96/7s came with this pipe from the factory, but, no luck finding any at salvage yards near me. I know I can simply weld a pipe in place of it, however I would actually like to keep it clampable.
It doesn’t really change the exhaust note, if you have a muffler delete you might just notice more drone in the cabin, that’s pretty much all it was deemed necessary for first place, but it was cheaper to not use it so Ford deleted it. I never noticed an actual sound difference in an otherwise totally stock exhaust 94 vs a 97. It doesn’t make removing the trans or driveshaft any easier either, the whole back half of the exhaust it’s clamped to needs to come off regardless to just partially lower the fuel tank. Knocks off a little weight to the rear pipes I suppose.
If you don’t want a shop to touch it I agree with supergordo, scour the yards to find a 96-97 section. Factory pipes were a low grade stainless steel(I forget the grade but the one that rusts on the surface but never rusts through) so it’ll be better than the walker part that most likely was just aluminized mild steel
Related Threads
TCCoA Forums
1.5M posts
26.8K members
Since 2002
