You want your muffler under your drive shaft instead of your trunk? I'd just remove the resonator and get better muffler(s) put in the stock position. And NO DAMN FART CANNON exhaust either!
it all depends on what you want and what direction youre going:
you can have one muffler with either a dual inlet and single outlet or with a dual inlet and dual outlet
or you can have two mufflers instead, that is what i have
as for size of the pipes...if youre just replacing the resonator then get the a muffler(s) with a 2.25 in inlet and outlet since all piping in a stock exhaust is just about the same...2.20, 2.22...
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
