‘05 F150 Reg cab, Flareside, Custom Ram cold air induction, Flowmaster
I’ll open this by saying; If this were a carburetor engine… but! Some background on me: I retired in 2007 from being a lifetime of working as a mechanic/technician since 1962. I’ve wrenched on bikes, motorcycles, cars & trucks.. gas & diesel. I installed & operated Yamaha’s Emissions Lab, worked for American Honda as a Senior Engineering Technician before returning to working at dealerships as a diagnostic technician/mechanic. But, I’m not a genus or a know it all! I’m working on my 04/05 F150 4.6L to improve performance (like many of us). It has the following: custom made CAI with Ram from in front of the radiator core support, the metered air side is a 3.5” ID MAF housing with a “laminar air” flow grid in front of the OEM MAF (6 pin), 3.375” ID tubing to OEM throttle body. I’ve reprogrammed using DiabloSport’s Intune i3 Platinum tuner, 87 octane custom tune, selecting the Roush CAI option,as well as the Airaid option. Either one has the same results; P0171/174 on hot restart. No matter how the MAF curve is adjusted, it’s just a matter of time before the codes set. No, there are no vacuum/air leaks! My conclusion is: intake air flow is huge compared to stock and greater than either of the listed CAIs. Recorded PID data is:
Both ST’s: +/- 2 to 3%%
Both LT’s: +30%
MAF count: 146.8-171.8
MAF reading: 5.18-5.23 at idle
Fuel pressure at idle: 39psi
My first inclination is to swap the 19# injectors (234k miles) for larger ones. My second choice is to replace the MAF with the 90mm Lightning L54 but that requires installing an IAT separately. So, is anyone ready to “play”?
Both LT’s: +30%
