1 - 2 of 2 Posts
My reverse lights dont come on when the car is in reverse, the only way they will work is if i am in between park and reverse. Does anyone know what could be causing this and how to fix it.
I'm pretty sure the MLPS (Manual Lever Position Sensor) is also the switch for the lights. So either it's bad (very common problem with the early MLPS's) or it needs adjusting. It is located on the side of the transmission and tells the EEC what gear the transmission is in.
Since the early ones are so prone to have problems, I would probably just get a new, later style and start from there.
Hope that helps. :thumbusp:
1 - 2 of 2 Posts
