There's an easy way to do this... You will probably have the front of the car on jackstands (because the wheels are still off), so you simply put your floor jack under the lower control arm where the strut rod and spindle connect, and carefully raise that side off the jackstand (about an inch should do). That loads the suspension (sets the ride height). Once you have torqued the UCA nuts, lower it back down onto the jackstand and do the other side. This really only applies if you are using control arms with the stock rubber bushing material. If you are using poly bushings, preloading the suspension isn't required...
