Found the rims i want, but the whole spacings are 5x135mm and for our cars they are 5x108mm correct?
If I need the changed to meet our spacing whom can I contact and is it possible to get new wholes put in without affecting the current ones? Is the 135mm too close to allow wholes to be drilled for 108mm?
Todd
Full Metal
dude the spacing for our cars are 5 on 108mm, or 5 on 4 1/4", i don't know if you can get them redrilled, you probably can but it would cost a little extra, imho find the ones with the correct bolt pattern, less of a headache, if not try a hub swap for the 5 lug mustang pattern, you could find alot more rims in that bolt pattern then you could with "ford's idea of a cruel joke" 5 on 108mm bolt pattern...hth.......later'z.......:D
Full Metal
try to get them redrilled then, maybe a machine shop can do it, or a wheel dealer can send them off to be redrilled, that's all i can think of right now, maybe someone who has had some rims redrilled will chime in here to offer a suggestion...later'z.....:D
