I am going to do a 5x4.5 rotor swap on my wifes 95 cougar and I was curious if I could fit 17x9 rims on the front and 17x10 rims on the back also I wanted to know if I was able to do these rims could I fit 300 or 315 tires on the back.
do u know the backspacing? i wouldn't see why not theres a guy on here running 17x 10.5 saleen style rims. i think the back spacing on those wheels are 36mm
24mm offset for the front and 27mm for the back also do you think I can get 315s on the back for the fron I will just use 275s
The fronts are going to be hanging WAY out...I would have to suggest a 17X8 front wheel with that same spec and you will be fine. Otherwise its going to look totally WRONG.
Brad
