I called Dan to order PI cams this afternoon. He said there are two types of PI cams -- Romeo and Windsor. Most guys are using the Windsor cams. Dan checked on the computer and my '97 Thunderbird has a Romeo engine. Would using Windsor cams be a problem or should I go with the Romeos? The Windsors are each about $15 less than the Romeos, so if I could save a couple of bucks that would be great.
Most people use the Windsors because it's cheaper to do so. Romeos have bolt on sprockets while the Windsors are pressed on one piece jobs. Either will work just fine.
One of the things I was wondering about was why Ford would switch from the pressed-on sprocket to the bolted-on sprocket. Is there a quality difference?
Fry Rice Specialist
can i use my 96 npi cam sproket on the pi cams provided i have the right bolts?
High-Mileage 4.6L Thrasher
Yes,you can-but only on the romeo cams.
JL
