Rough idle and SES light after intake manifold replacement
Hi all,
Intake manifold, all appropriate gaskets, plugs, plug wires, T-stat, and injector O-rings replaced about 8 weeks ago. Engine ran fine until about 2 weeks ago, when rough idle started and SES light simultaneously came on. I replaced IAC twice, but rough idle and SES light came back within a couple days. Engine otherwise runs smooth as silk; no problems. Any thoughts? Haven't yet pulled any codes.
Could be a vacuum leak or egr malfunction, maf malfunction, etc. Once you pull the codes you should have a pretty good idea. Did you retorque the manifold after a heat cycle?
Without pulling the code, you are just guessing. I learned the hard way on that one before.
First I heard of this. Then again, people are re-torquing everything these days, a little excessive if you ask me. I bet a lot of mechanics don't even torgue them in the first place, so as long as they were torqued on install, you are ahead of the game.
Al
Hi all,
... etc ... rough idle started and SES light simultaneously came on. ... etc ... Engine otherwise runs smooth as silk; no problems. Any thoughts? Haven't yet pulled any codes.
I have no idea what year your car is ... but when my 1995 did that I found it to be the tee in the vacuum line that operates the EGR, hole melted opposite the side leg. Dorman replacement and I added a shield behind it .... and I have a spare now in the glove box. http://forums.tccoa.com/7-engine-4-6l-5-4l/142542-vacuum-line-replacement-article.html#post1818514
Now, my '92 ..... did need a new IAC, but that's a different apple. :smile2:
Pulled the code. Said it's the egr management valve. Looks like the vacuum hose to it is dried out/cracked. Could be the problem. Damnedest thing, though...SES light stopped glowing yesterday driving home from work without my fixing anything. Now idles fine again. WTF??!!
