i guess a chip is the answer, but its a pretty vauge question. it will change your shift points and shift patterns but it seems like you really just want a manual transmission. or maybe im just not reading right
if you just want to keep it from shifting to the next gear you can control that with the shift lever. you can shift through the gears with the transmission semi-manually if you want.
