1 - 20 of 28 Posts
Gentlemen, My totally stock 96 cat had been standing for a while. It would not start and my trusty 90 Nissan Maxima just kept chugging along. Finally replaced fouled up CAM AND CRANK position sensors and it fired right up. Now it shows a CEL which I can't have diagnosed till weekend, but here are the symptoms.
Heavy gas consumption.
On start-up I accelerate smoothly to 45mph. The tach will show about 2000rpm, then in high gear it will fall to 500 and not move, as if disconnected. When this happens the car vibrates as though I'm running on those rumble strips they have on the shoulders of the highway. This is intermittent and lasts about 15 to 20 seconds each occurrence.
Any Ideas what's happening here?
The rumble strip effect is usually torque converter shutter. You check the fluid?
Thanks for your response Joe!
Transmission fluid level is OK on the dip stick. If you meant check fluid in the Torque Converter, I have no Idea how to do that.
I thought the fluid looked a bit brown and thin, not dark and thick as old oil from the crank case might look. But the tip of the dip stick is coated in a yellow plastic material so I don't know how that affected my perception. However, I am going to have it drained and replaced as that has not been done since I've had the car. I've only put about 5K miles on it in six years.
So I searched the forums and I learned that
1) TC shudder or stutter is a well documented problem with 4R70W
2) That transmission fluid is pink out of the bottle
3) That brown, even light brown transmission fluid on the dipstick is NOT a good sign
4) DIY fluid Change involves dropping the pan, draining the TC and 13.5 quarts of Mercon V.
Q's
Why drop the pan? is there not a drain plug?
Can anyone point to a detailed instructions on #4?
Mercon V seems to be a formulation. Any brand preferences? Cheaper by the 5gal Pail?
1 No drain plug on the pan.
2 There's a rubber cap on the bottom on the trans, pull it off and turn the engine until the TC plug is visible, then take it off and let it drain (about 30 min or more)
3 Mercon V is Mercon V. As far as I'm concerned it's all the same. Get it from advanceauto.com and use a coupon code.
Moved to 4R70W forum, you might see more activity from experts! :tongue:
I will add that not all converters got the drain plug IIRC. Can't remember when they started phasing them out but thought it was sometime in mid 96. Some people seem to have one while others don't.
Also, the Valvoline version of Mercon V has a strange smell to it even when new in the bottle. It already smells burnt to me. I just did a trans. service on a 96 bird using Motorcraft fluid and was about 1/2 quart short so I bought a quart of Valvoline and used that and that's when I noticed it.
Converters lost the drain plug in 01, The shudder is most likely the converter. I do however suggest doing some checks in the transmission while you have it out. You are clost to Dan at Silverfox. I suggest you go see him.
Alan
Alan
Alan, can you clarify Dan's location? I'm fixing to change the fluid in an effort to get rid of the rumble. Unless that creates more problems ,(i've read about slippage after fluid change) more extensive work must wait until my DD is up an running again.
Dan is in Pleasant Hill,MO
Usually by the time there is a problem changing fluid will only make it worse. The converter clutch is probably gone. There have been a few cases of people who got more life after changing the fluid, most do not. Fluid is about $5 a quart and you'll need an entire case. Expensive to do twice.
Alan
Tire & lube shops here test drive the car, and if there is a hint of transmission trouble they wont change the oil.
APART FROM 14 QUARTS MERCON V WHAT ELSE DO I NEED TO COMPLETE THE JOB?
GASKET?
IS THERE A FILTER ?
HOW IS THE REFIL DONE? THRU THE DIPSTICK?
AND HOW DO I OBTAIN THE COUPON CODE FOR THE ADVANCEAUTOPARTS PURCHASE?
GASKET?
IS THERE A FILTER ?
I think your caps lock button is broken. So is your search function.
Gasket is reusable
Is there ever not a filter?
Yup, dipstick.
Google.com
Discussion Starter #14
Gasket is reusable
Yup, dipstick.
Google.com
Thanks for your input 1996project-bird! The button ain't stuck, but when you look up after hunt-and-pecking a few sentences and see that it's all caps you're not about to retype, umm... re-hunt-and-peck it all over again.
As to the search function, that has turned up so many contradictory opinions I just decided to stick with the people talking to me. So when it cools down this evening I'm going out under the shade tree and look at the transmission, kinda try to locate all the stuff I've been told; familiarize myself with the underbelly of the cat. Got one more question for you. I know Google is a search engine. Do I just type in ADVANCEAUTOPARTS COUPON CODE, hit enter and the desired goodie will pop up?
For Advance, I order online and select the pickup in store option. Along with that I use the P20 coupon code for 20% off. That coupon is online only, which is why I use the pickup in store option.
You need 10-12 quarts of Merc V and a new filter. Might not be a bad idea to put a drain plug into the pan as well while it's down.
Discussion Starter #16
Thanks Brandon. I'd just discovered that myself. JU15 is good till tomorrow, July 1st
Theres a lot of coupon codes better than 20% off. Big35 is 35 off of 85 (more than 20%). Just one example. Google advance auto coupon codes then go to a site called retailmenot. It has a lot of codes it all depends on your total in your cart.
Hmm, did not know about that one. I usually don't spend enough to qualify for that coupon though, so most of the time the 20% coupon is my best option.
Discussion Starter #20
So, lets have a few more laughs at my expense.
Laugh #1:
Normally I'd pop down to Advance, two miles from my home and purchase a fuse or bulb or whatever I need, pay by my debit card and leave. This time, lured by the 15% discount and a 25 dollar coupon valid next month, I shop online. That part went well. Check out said that I needed to take the email they were sending me along with my card and ID down to the store in order to pick up the purchase. The Email does not arrive so I wait. Next day I call their 877 #. I'm told to go in with the order number I gave the customer service person. Sure enough, fluid and filter and a few other items are there boxed and waiting for me. Been there since store opened on the morning before. Two days wasted.
Laugh #2:
Totally misunderstanding the instruction regarding removing the line to the radiator and attaching a hose with a flare fitting, instead of attaching the flare fitting and hose to the radiator, I attached the hose to the flare fitting that I Detached from the radiator. Needless to say, after starting the car, I now have transmission fluid splattered over most of the driver side of the engine compartment. Okay! I'll wait for you to finish laughing!!
Now more questions. Where is the HOW TO?
Several times I have seen the suggestion that while the trans pan is down I might as well add a drain plug to it. Of course the benefits thereof are manifest, but despite my search I have not found any instructions on how to accomplish that.
And finally, what transmission is in a civilian Crown Victoria? If 4r70w, is it bolt compatible with the cougar 6 or 8 cylinder. Would you buy an otherwise solid CrownV for 500 if all it appeared to need was transmission work?
1 - 20 of 28 Posts
