Hi. has anyone ever used those after market rust repair quarter panels they have?
I'm thinking of getting at least one, maybe both for my 95 t bird. But they are a little over $100. and shipping is another $112. Was just wondering how they fit. It would save me a lot of time over making my own. I already have the lower door skins and rockers from sherman. Thanks .
That's a lot of rust repair and there is probably more hiding. Does the car have sentimental value? The general agreement here is that it's easier and cheaper to buy a rust free car than to repair rust. These cars just don't have the value.
-Bryan
Kind of. We have had that car since brand new. Got both kids thru College. V8, runs great, only has 110,000 miles. took very good care of it.
Actually, yesterday I picked up 2 1997 t-bird VERY clean doors, a very clean fender, all the wide side moldings from pick a part for 150.00, a steel if you could see how clean these part are. Im an ex-bodyman so will be doing most myself, I may take it to be painted, I haven't decided if im going to paint it myself or not.
Being in the UK, I'm not 100% sure which section you refer to as the quarter panels. Rear wings? I just had the rear section of the rockers repaired on mine, and the guy that did it let a little section in that e made himself, as it wasn't too big.
Gotta fix 'em up, in my opinion. Good luck :)
The quarter panel is the rear panel of the car. The rust is at the bottom about 6 inches up the panel. The rocker is also rusted out below it to. I have the rockers already.
Ah ok, same as over here. The but directly behind the rear wheels. When I had my rockers done, I painted te repaired sections myself (as they were only about 12" long), I had an aerosol mixed from the paint code by a paint company, and the match was absolutely spot-on. You'd never have known anything had been done.
I am still evaluating, but I 90% sure I will be fixing my rockers this Spring. I know it may not be perfect, but it will be solid and be better than what is there now.
The other option is to find a southern car, but after I added up all the suspension work, transmission, interior, brakes, front end, rear end, driveshafts and a million other things, I couldn't make all that work cheaper than just fixing what I have. My car is pretty much new mechanically.
Sure, I wouldn't mind a 1996 so I can put the PI stuff on there, but after buying a $2000 or so car and transplanting everything, it would cost more than my estimate.
