S-Model Supercharger &
70mm TB 'How-To'
Note: Before beginning it is recommended that you
read the SC
OD Pulley install 'How-To' for pulley removal and the Spark plug wire
installation 'How-To' articles. You will need the Supercharger Reseal Kit
E9SZ-19577-A which is available from your local Ford parts department or
any Gasket Maker (requires 6-12 hours set-up time). You will need about
4 hours to complete the removal and installation of the supercharger, throttle
body, and inlet plenum. S-Model supercharger and 70mm BBK Throttle Body
can be purchased through MN12
Performance.
Hint: If you never cleaned the Intercooler out or
flushed the radiator this is the best time. Use mineral spirits or a can
of brake fluid to clean the Intercooler out and radiator flush to clean
the radiator out. This is also the best time to mount a intercooler fan
behind the intercooler.
Installation is the reverse of removal.
Torque Specifications
(*) - Fully seat then tighten to (17-88 lb-in)
70mm TB 'How-To'
read the SC
Performance.
- Designate a clean area to set the parts down after removal from the
car.
- Disconnect the connector to the Mass AirFlow (MAF) sensor
and loosen the clamp at the Throttle Body. Remove the air tube assembly
from the Throttle Body (TB) and pull the air intake system
out. Disconnect the #1,#2,#3 plug wires from the distributor.
- Disconnect all (accelerator, speed sensor, & AOD) linkages from
the TB bracket. Next, remove the 2 bolts that attach the TB bracket to
the inlet plenum assembly.
- Disconnect fuel charging wiring connectors at the throttle position
sensor (TPS) and idle air control (IAC) from the
TB.
- Remove the supercharger belt & pulley (see
SC OD pulley installation article)
- Remove all vacuum hoses that connect to the inlet plenum. (Hint:
Mark the location of all vacuum hoses that are connected to the inlet plenum
before removal). Loosen supercharger bypass hose clamps
that connect the inlet plenum to the outlet plenum.
- Remove the supercharger outlet plenum collar nut with the spanner nut
wrench and remove the 2 nuts that connect the upper intercooler tube assembly
to the intercooler.
- If your SC is equipped with a Exhaust Gas Recirculation (EGR)
valve you need to remove the two bolts that connect the EGR valve to the
inlet plenum along with the bolt that connects the EGR transducer. You
will have to remove the passenger side cowl vent screens to access the
EGR. You will need a 3/8" flex head ratchet to reach the 2 bolts that
hold the EGR to the inlet plenum. If your SC is equipped with the coolant
lines that run through the TB you will need to block the lines off.
- Finally, remove the three bolts that hold the supercharger down to
the intake. Remove the supercharger, intake plenum, & throttle body
together from the car. Clean as much oil and dirt from the engine as possible
using brake cleaner or engine cleaner and compressed air. With the supercharger
out check all vacuum hoses for signs of cracking and check valve covers
for oil leaks. With the stock supercharger out of the car check all vacuum
fittings on the inlet plenum and swap any fittings over to the S-Model
that are different. Remove the 4 bolts that hold the SC top on the supercharger
and remove the SC top. Clean and inspect sealing surfaces. Remove the 4
retaining nuts from the stock TB and separate the TB from the inlet plenum.
With the TB off remove the IAC and TP sensors. (Note:
Be careful the screws are very hard to get off so use a bench and a good
phillips head screw driver to remove the screws. Install both IAC and TP
sensors on the new BBK TB. Tighten the IAC bolts to 6-9 lb-ft and the TPS
phillip screws to 6-9 lb-ft. Check all nuts and bolts that connect the
intake plenum to the supercharger and torque to proper specifications.
- Check the TP voltage after you install the TPS on the TB. To check
voltage connect the TPS connector to the TPS and using a paper clip insert
one end into the the back of the harnesses CENTER wire in the 3 wire harness.
Turn the ignition to ON with the engine off and check the voltage using
a volt meter. At idle the voltage should be between (see chart).
To adjust the voltage turn the idle stop screw down until correct voltage
range is achieved. If correct voltage cannot be set then remove the TPS
and using a drill bit or chain saw file round the brass holes that the
screws go through to hold the TPS down to the TB. This will provide you
adjustibility when setting the base voltage.
Passenger Car Engine
Engine
1993 Service Part
Voltage at Idle
Thunderbird/Cougar
V6 3.8L EFI
F2SZ-B
.66-1.22
Thunderbird
V6 3.8L SC
F2SZ-C
.70-1.31
Thunderbird/Cougar
V8 (4.6L) EFI
F2SZ-A
.65-1.26
Thunderbird/Cougar
V8 (5.0L) HO
F2SZ-C
.70-1.31
Description | Lb-Ft |
Supercharger Retaining Bolts8mm | 15-22 |
Supercharger Retaining Bolts12mm | 52-70 |
Supercharger Outlet Adapter Bolts/Stud | 15-22 |
Throttle Body Assembly Retaining Nuts | 15-22 |
Intake Elbow Bolts | 20-28 |
Charge Air Cooler Tube Retaining Nuts | 15-22 |
Charge Air Cooler Outlet Tube to Bracket Bolt | 30-40 |
Supercharger Adapter Collar (Nut) | 148 |
Charge Air Cooler Outlet Tube Bracket (to Cylinder Block) Stud | (*) |
Charge Air Cooler Outlet Tube Bracket (to Cylinder Block) Bolt | 52-70 |
Charge Air Cooler Outlet Tube Bracket (to Cylinder Block) Nuts | 15-22 |
Charge Air Cooler Retaining (to Radiator Air Boot) Screw and Washer Assys | 3-5 |
Generator and Power Steering Pump Bracket Nut | 30-40 |
Throttle Linkage Bracket Bolt | 10-15 |
Bypass Hose Clamps | 20-30 (Lb-In) |
Sensor Assembly | 6-9 |
Power Pump Bracket Brace to Water Pump | 15-22 |
Plenum Bolts | 16-24 |
Charge Air Cooler Outlet Tube Stud | 17-88 (Lb-In) |
MN12 Performance [email protected] 703-968-6513 |
