I have a 1995 TBird with the SATC - and have been having some odd issues.
- SATC module is "new" (pull from pick-n-pull - but - the wear on the unit isn't typical of the age of the car, I'm guessing it was a replacement for the car it was in.) Module was replaced since the AC portion / vacuum line area was falling apart.
- Temperature Sensor is new
The outside temperature is correct "some times" - during mornings its the right temperature (I call within 3 degrees of the nearby weather.com OK) but, during the middle of the day, it gets hung on that early morning temperature.
If I perform a test on the SATC module, it passes with no error codes, and then displays the correct temperature.
Example:
Morning AM - 67 degrees (weather.com 69)
Afternoon - 73 degrees (weather.com 95)
Afternoon after SATC test - 98 degrees (weather.com 98)
I'm at a loss on this one - especially since it goes to correct after the SATC test.
There is a reference temperature measurement in the computer; if it's hotter than the outside, there's an error until it clears, apparently.
My car(s) will read correctly after the inside of the car cools down.
Interesting, mine does this (sort of) as well. It takes a few moments for it to "catch up" to the outside temperature sometimes.
There's a fan, filter, and a temperature sensor behind that little grill on the dash, beside the radio.
I bet mr. fan is toast.
:D
Do you have more specifics as to where that fan/filter is at? I know the interior SATC temp sensor is behind that little grill next to the radio and there's a duct behind it which leads to the main blower motor cabinet...
I've never had ours apart; that's the way the Fox body Tbirds were, tho. I fixed my Dad's, years back.
If there's a duct, it pulls air in; it's sampling room air by design.
A gap in the duct, or something plugging it will make it not work well; it needs to move air, or it doesn't work.
(may try some MAF sensor cleaner).
Don't get that on the dash, it will crack in a bit; it's bad for the plastic. Iso alcohol is about the worst you can use without damage.
I'd bet taping the joints in the duct Brandon mentioned will fix the problem; I'll look at the one in Lazarus, he needs a stereo. :)
