will an exhaust from an sc go on an lx. i want dual but mostle for looks. will it sound any diffrent if instead of puttung on a resonater i put in a glasspack. will this work and how will it sound on a 3.8. thanx
but, the SC resonator is shorter, so you'll need to cut about 2" off the SC exhaust and put on a new fitting. I had this done at a muffler shop for about $30. Make sure you get the extra exhaust bracket up under the rear bumper.
I can't really give you the performance numbers, but it does sound a bit better.
I guess if you use a custom glasspack setup, you can probably get it all to fit without having to cut the SC exhaust.
