Im wondering if its possible to put the SC side GFX on my car, with the damaged rockers..
Heres some pics..
Drivers side:
Passengers Side:
Another angle:
Stay away from those curbs and tire stops! Worse case, just pull them out to a reasonably close shape, then install the ground effects. Besure to seal the holes to keep moisture out....
wow thats crazy, mine is a couple inches lower and i have a tiny ding in my rocker panel. do you take it "Off Road"? :D
if that were mine id try to get the rockers strait as possible and rust free then think about some ground effects. your probably gunna crush them seeing as they sit lower than the rocker panels anyway.....
