1 - 10 of 10 Posts
Are the XR-7 springs the same spec as the Supercoupe? As far as stiffness goes. I'm looking for a set to upgrade the stockers on my 97. I considered buying Eibach's or Vogtland, but from what I hear the SC springs are a good bit stiffer. If the XR-7 Springs are the same that would be perfect as there are quite a bit more cougars than thunderbirds at the local yard. Thanks!
That's kind of what I need to know. The only XR-7's I can find at the yard are V8's.
89-91 XR7s got SC springs. 96/97 tbirds and cougars with the sport option also got the same springs.
Thanks for that, now I know what to look for.
The 91 XR7 did have the exact same suspension as the SC. They aren't that uncommon, its just that most of the ones you find have been beat to snot.
I didn't know whether the 92s got the SC suspension or not. Then again, I've only ever seen one 92XR7, so they are probably pretty hard to come by.
1 - 10 of 10 Posts
