Good idea or bad idea? Does this stuff actually work? If I put it in my gas, will the car smoke until I burn it all out and refill? I just want to get a second opinion.
yes it's a good idea, no it won't smoke if you put it in your gas. if you put in a vacuum line it will smoke like crazy but only for a little bit.
My friend used it in his '89 Subaru and he saw a difference. I didn't see it. May have something to do with how underpowered it is. But, I'll give it a try when I put more gas in the 'Bird.
I ran it though the crankcase and the intake and I saw a difference in overall performance. The car just runs better. In fact, my buddy is getting ready to run through his 87 Mustang GT due to the before and after.
Our cars (and most new cars) recycle so much crud thru the intake that seafoam is a necessity.
Even with good compression results, my car seems to injest a lot of oil vapor and droplets thru the pcv circuit; an oil separator seems to be in my future... (or the new engine, if I ever quit dinking with it...)
I started using seafoam every oil change, and it made a difference for over a year; now I do it every other oil change.
