21 - 23 of 23 Posts
There are videos out there of the j-mod, and it sure looks easier with the trans out of the car and upside down than it does under the car with it dripping transmission fluid.
Al
  • Like
Reactions: Grog6
Just about any JY transmission is going to need a rebuild at this point; the best you can do without a good transmission guy is an 02 4r70w from agran marquis or crown vic, but the non-police version.
all the rubber is hard as a rock, and using the one piece seals makes them last.
If you install the "supertuff plate" from patc does the jmod, but you need to replace the 1-2 accumulator too.
  • Like
Reactions: supergordo
I would say the hardest part of doing any J-mod is the snap ring for the 1-2 accumulator piston. Then again, I had crappy snap-ring pliers at the time.
The most frustrating part.... is the mercon bath. Get the Dorman pan with a drain plug instead. :)
21 - 23 of 23 Posts
