where is this thing located. is it the two part box with a bolt through it that hangs on the emerg. brake pedal bracket? if that is not it then what is that box with all the wires for? i really need some help here. been a long 1 1/2 months chasing wires and my next solution is a match. thanks wes
yeah i know about the fuse block and power dist. box. i need to know where the secondary junction box is at. im pretty sure that is where my problems are but nobody knows anything about this mystical box wes
Pedal Faster
In the '90 the EVTM says: Secondary Junction Block, Base Part No. 14448, Behind LH side of I/P [instrument panel], RH side of steering column.
Hope that helps out.
