So driving to work an hour ago and stoped at a stop light, ac on, light turn green and half way throug the light get a lot of somke through vents. Stop imedieatly shut car off and open hood. Serprntine belt webs every where. So i assumed that is was just old and died, not, the tensionar arm pully is hard to turn. Is this right or not? Is this a hard fix? ( the poully?)
Jon
The pulley is shot.
Simple fix, as long as you have a breaker bar with 1/2" lug.
The pulley on the tensioner can be replaced without removing/replacing the tensioner.
It is the same EXACT pulley as the idler, and should cost around $11-$13
Discussion Starter · #3 ·
I know how to replace the belt...how do i get the pully off? Is there a bolt on the back side i dont see?
Jon
Had to refresh my memory, and go look at mine.......
Take the three bolts off that hold the tensioner unit in place.
Then you will have access to the bolt.
Chapter Director Coordinator
yes
the tensioner really does need to come off to properly replace that pulley
Discussion Starter · #6 ·
Great, thanks guys for the help- i will probably be askin more questions in the A.M. when it comes time to actually do the work.
jon
