11.5" bolt pattern 164 tooth
TCI Ford Small block flexplate
11.5" bolt pattern 164 tooth.
Code: 529620
This is a brand new flexplate, was bolted to a motor but never started. No wear on the teeth at all.
For Ford applications, TCI® OEM-style small block flexplates are constructed to precise standards and are SFI 29.1 approved. Built extra-thick with welds on both sides of the ring gear, these flexplates are precision-balanced and checked for runout.
11.5" Bolt Pattern, 164-Tooth
If your unsure if this will fit your vehicle, contact the part manufacturer
new from tci they sell for Price: $91.73
will take $75 for it.
will it work for the 95 sc motor?
According to TCI website...
Ford SFI Flexplates C4/C6
These small block flexplates are constructed to exacting standards and are SFI 29.1 approved. Built extra-thick with welds on both sides of the ring gear. These flexplates are precision balanced and checked for run out. These work with 289-351C, 351M-400M engines.
Description Part No.
Ford small-block, 157 tooth, 0 oz., 10.5 inch bolt pattern 529615
Ford small-block, 157 tooth, 28 oz., 10.5 inch bolt pattern 529618
Ford small-block, 157 tooth, 50 oz., 10.5 inch bolt pattern 529610
Ford small-block, 164 tooth, 0 oz., 11.5 inch bolt pattern 529625
Ford small-block, 164 tooth, 28 oz., 11.5 inch bolt pattern 529628
Ford small-block, 164 tooth, 50 oz., 11.5 inch bolt pattern 529620
