What I would like to know is while i have the trans open is there anything i should replace while i have it open.......i am installing a B&M Shift Kit (I know ill get flamed for the B&M but i have had success with them in the past and i have a 91 AOD so the Jmod is out) ive never done a Ford shift kit...i only did Chevys when i was younger......also the shift kit is just for the summer until i save some cash for the Valve Body from PA..........i have tried to read and search the forums but it all seems geared toward the 94 and newer Transmissions I just wanna make sure that while i have it open i can change any small things that would be a help
Thanks
Steve
PS im also doing a trans cooler
MOD OR WHOEVER NEEDS TO PLEASE DELETE THIS AS IT SEEMS I WONT GET AN ANSWER
Johnny Bling Bling
the only thing that you should need to replace when you are doing the shift kit is the tranny filter and gasket. you want to drain the complete tranny of fluid, including the converter, and refill with mercon 5. i have an aod as well, though i used the baumann kit, and i switched to mercon 5 with no problems as of yet. everything else should be included with the kit. good luck.
High Output Poster
You might want to consider upgrading to the A servo OD. The part numbers to upgrade are on Baumann Engineerings website.
Uh-oh... I'm no expert but Mercon V in the '93 and earlier AOD is a bad idea. I can think of 2 people with 86-93 stangs that put merc V in their AOD and it failed and one with an 88 Mark VII AOD. They start slipping supposibly and have realy sluggish shifts and is caused by the fluids synthetics. They break down the old seals in the trans. Also the clutch packs are not designed to use a synthetic like '94 up AODE's and 4R70W's. I would just go with the OEM merc III from the factory like Motorcraft and add a trans conditioner like from BG (they also make awsome fuel system cleaner too) and you will probably find it at local shops or some parts stores. I wouldn't recomend using merc V unless the trans has had a complete overhaul/rebuild.
Now, as for the shift kit the B&M will be great cause you have 2-3 different plates you can install and its easy. I helped a friend install one on a '91 5.0 stang notch back. We installed the street/strip plate and it would break 245/45/ZR17's w/ 1-2 shift and had neck snapping 2-3 shift and over drive was very sudden. The Transgo is very good too.
Hope this helps alot
Clay
PS - I'm not an expert, its just from experince
PSST - the seals in the AODE and the AOD are the same thing. And many of them are also the same in the 4R70W. The designer suggests Mercon V, and I'll stick with that.
[soapbox] I don't understand how people run trannies for 150k+ on the original fluid, change it, then have the tranny fail 5k later... and then blame the fluid. it wasn't the fluid that killed the tranny, it was the 150k miles of poor maintenance before then that killed it. [/soapbox]
:zsoapbox:
High Output Poster
:zsoapbox:
Exactly.
