1 - 11 of 11 Posts
Just curious on which shift kit would be the best to buy or should i do the jmod?
you get the whole search ordeal thrown at ya on this.
J mod it. Better shifting, longer life of tranny. and if you can, throw in a tranny cooler while your at it...even longer life.
Ok cool thanks. I know i'm gonna get alot of opinions on this subject but i was heading towards the jmod just seeing if anyone had different opinions
You will be best served by The Master's "J-MOD":ztoohot:
Maybe someone can help you with part #'s - drill bit size's ect :)
I can only say, read the procedure over and over, till you are sure
of what is to be done and go at it !!!!!!!!!!!!!!!!! I did mine - and at
first read - I didn't feel I could do it ,BUT :) everything came together
nicely !! and YES to installing a Trans Cooler B&M makes a nice kit.
Hope this Helps Curt
I just got a performance automantic valve body I still have to install it.
I had a local tranny shop do the J-Mod for me. Brought them print-outs of the pertinent Tech Articles, and they said "no problem". However, they said they weren't sure how long it would take, and gave me an estimate of 3 to 5 hours, at a labor rate of $45/ hour.
Provided all the parts, including a pre-drilled separator plate.
$100 in labor and it was all done.
The Shop was;
Ralph's Transmission Shop
Albany, NY
Cool. There's a Mr Transmission in the area that was recommended to me. Supposedly they will do custom work like shift kits and stuff, so I'm hoping they'll do a j-mod, TC install, and flush/fill with Mercon V.
Does anyone recomend the trans go shift kit over the jmod?? And i was curious if anyone that has done the jmod replaced the 1-2 2-3 accum pistons on the 94's Is it recomended?? And my final question is what does the trans go kit come with?? Parts ect...
Very few people recommend the Trans-go over the J-Mod.
Yes, you should do the 1-2 and 2-3 accum's on your 94.
Also, you should take advantage of the Search feature here.
I bet if you type in the word "Trans-go" you will find lots of interesting comments.
Do the J-mod. Trans go isnt recommended over J mod but it is over the B&M tranny products for our cars.
1 - 11 of 11 Posts
