Well... just like it says, I completed the models for the linkage between the actual shifter and the dummy shifter. My measurement came out to 7-5/8" from hole to hole. This is with the dummy shifter nicely centered in the AT console opening.
It should be under $20 in materials and 2-3 hours on my dad's milling machine.
The link itself is 1" X 1" cold-rolled steel bar, bushings are hardened oiled bronze (0.5" OD X 0.375" ID X 1" long) the fasteners that hold it all together are a hardened steel shoulder bolt with a .375" X 1" shank.
I'll pass on the mechanical drawings if anyone wants to build one for their current T45 project:)
Sorry the pics kinda suck... I couldn't get a screen shot into a JPEG so I just took a picture of the screen: http://s1132.photobucket.com/albums/m571/Triston30/T45 Swap/
Enjoy!
Triston
Are the bolts designed to thread through the existing holes in the shifter? Or are you designing them to drill out the shifter and make it just a pass through hole?
The threaded holes in the shifter handles will be clear-bored to accept the bushing with a 0.0005" interference fit. I figure with a larger cross-sectional area of the shift lever taken up by the bushing, the load will be better distributed; minimizing localized stress points and yeilding an extended service life of the bushings. It should have a very solid feel to it. I'd like it to feel like there's no extension at all.
I guess we'll find out this weekend.
I see what your saying. I would imagine that would firm everything up pretty well. The only down side to that, and maybe its just a down side to me, is once you drill out the holes in your shifter, I can't be used for anything else. If you wanted to try a different shifter you couldn't re sell that one because the holes are drilled out. Not unless you find someone willing to re drill their handle to take a larger bolt and re tap eveything anyways. I'd like to find a way to thread a piece in there somehow and put the bushings on the ends into the linkage itself and leave the shifter into a stock configuration. Thats the biggest gripe I have about my setup, fairly tight but I can feel slop in it and it rattles.
That's kinda what I was afraid of... slop & rattles. (Not trying to beat up on your work).
I'm just using two stock T-5 shifters though. You can score those on craigslist all day for $15 a pop so I'm not too worried about hacking them up. I already welded the dummy shifter together anyway so it's useless outside a Tbird/T45 setup.
I'm hoping to have it all machined & installed by the end of this weekend. I'll be sure to post how it turns out.
Triston
No beat up on my work all you like, I'm ok with how it is, but I am long ways away from liking it. And yeah if your using stock shifters I wouldnt worry about modifying them to fit anything, I hacked the stock shifter Im using in my setup all to pieces. But in the trans I have a Pro 5.0 short throw. So if at sometime I wanted to sell it and try something else, theoretically I could, because it's not modified in anyway. But yeah let me know how it works, my mind is always working trying to figure a way to improve my setup.
I would like for you to send me the prints. I am about to start my own swap soon, and would appreciate any prints or knowledge you can pass along TY
