Ok, so my cars been acting weird lately.
Basically when I go to put it in D from park it seems to go into neutral, sometimes it goes in, sometimes it will catch when I give it some gas.
When I put the car in 1, its 100% fine, same with 2, 100% fine, holds the right gear and does what it should, no slippage.
Does this sound like the shift position sensor has gone bad?
I have had intermittent issues with it wanting to go from 3rd to 4th back to 4th and so on randomly as well.
Its a built 4r70w, never had an issue with it otherwise.
ive had this issue before. deff the sensor. they call it a neutral saftey switch.
heres a part number from standard motor products. NS95.
when replacing make sure you line it up right otherwise reverse lights wont work. happened to me once.. got a ticket for it. quite easy to do. just make sure the car is cold since its right next to the exhaust.
Thank you sir, I will be replacing that stupid thing.
Yea, I just switched to a turbo setup and I have a single pipe that runs right by it, maybe that was enough to knock it out completely lol.
Its weird that it will go into 1st and then neutral if I give it too much gas though.
Anyways, Napa wanted like 75 bucks for some no name brand to I called ford and they wanted 85 bucks...
Guess im going with ford.
