21 - 33 of 33 Posts
I can't believe it's CARB legal for CA; I didn't think you could do that. :)
As long as you go through the testing to get that CARB EO number proving it won't harm emissions, you are good.
Looking at the list of what's CARB certified that can work with the tbird, it seems like the tbird was "close enough" to the crown vic or mustang to gain certification.
I'd be surprised if you could justify taking your product through this process JUST for the tbird market.
EO: D-423 View PDF
EO Date: 1997-04-09
Manufacturer Name: Allen Engine Development
Device: 6 PSI Supercharger Kit
Device Type: Supercharger System / Supercharger Modification
Part_Number: Model_Specification: Modification_Allowed: Remarks:
1994-1995 Ford Crown Victoria/ Grand Marquis/ Town Car 4.6L 1994-1997 Ford Thunderbird/ Cougar 4.6L 1996-1997 Ford 2-valve Mustang 4.6L Kit includes Eaton supercharger with a 2.85" diameter pulley, intake manifold plenum intake manifold runners, intercooler, throttle body adapter, electric water pump, high flow fuel pump, and fuel pressure regulator. EGR valve is relocated between the throttle body and the supercharger intake.
EO: D-423-1 View PDF
EO Date: 1998-03-10
Device: 6 PSI. Supercharger Kit
Ford 4.6/5.4 liter applications excluding any vehicle certified to a transitional low emission vehicle (TLEV) or low emission vehicle (LEV) emission standard: 1994/95 Crown Victoria, Grand Marquis, Town Car, 1994-97 Thunderbird/Cougar, 1996-98 2-valve Mustang, and 1997/98 trucks. The EGR valve is relocated between the throttle body and the supercharger intake. Stock air cleaner is maintained. Eaton supercharger with a 2.85" diameter pulley (passenger cars) or 2.94" diameter pulley (trucks), intake manifold plenum, intake manifold runners, intercooler, throttle body adapter, electric water pump, high flow fuel pump, and fuel pressure regulator.
EO: D-423-2 View PDF
EO Date: 1999-03-16
Ford 4.6 and 5.4L applications: 1994/95 Crown Victoria, Grand Marquis, Town Car, 1994 to 1997 Thunderbird/Cougar, 1996 to 1999 Mustang, and 1997 to 1999 trucks The 6 PSI. Supercharger Kit includes the following main components: Eaton supercharger with a 2.94" diameter pulley (4.6L) and a 2.4" pulley (5.4L), intake manifold plenum, intake manifold runners, intercooler, throttle body adapter, electric water pump, high flow fuel pump, and fuel pressure regulator. The EGR valve is relocated between the throttle body and the supercharger intake. Stock air cleaner is maintained
EO: D-423-3 View PDF
EO Date: 1999-10-19
1994/95 Crown Victoria, Grand Marquis, Town Car, 1994 to 1997 Thunderbird/Cougar, 1996 to 2000 Mustang, and 1997 to 2000 trucks, all equipped with the 4.6/5.4L engine. The 6 PSI. Supercharger Kit includes the following main components: Eaton supercharger with a 2.94" diameter pulley (4.6L) and a 2.4" pulley (5.4L), intake manifold plenum, intake manifold runners, intercooler, throttle body adapter, electric water pump, high flow fuel pump, and fuel pressure regulator. The EGR valve is relocated between the throttle body and the supercharger intake. The stock air cleaner is maintained.
EO: D-423-4 View PDF
EO Date: 2002-11-21
Device: Supercharger Kits
92-02 CROWN VIC./ GRAND MARQ. / TOWN CAR 4.6L V8 or 92-02 CROWN VIC./ GRAND MARQ. / TOWN CAR 4.6L V8 92-02 CROWN VIC./ GRAND MARQ. / TOWN CAR 4.6L V8 02-03 EXPLORER / MOUNTAINEER 4.6L V8 or 02-03 EXPLORER / MOUNTAINEER 4.6L V8 97-03 F150 / EXPEDITION 4.6L V8 97-03 F150 / EXPEDITION 5.4L V8 97-03 F150 / EXPEDITION 4.6L V8 97-03 F150 / EXPEDITION 5.4L V8 98-03 F250 5.4L V8 98-03 F250 5.4L V8 98-03 F250 6.8L V10 98-03 F250 6.8L V10 98 NAVIGATOR 5.4L V8 98 NAVIGATOR 5.4L V8 00-03 EXCURSION 6.8L V10 00-03 EXCURSION 6.8L V10 00-03 EXCURSION 5.4L V8 00-03 EXCURSION 5.4L V8 97-03 ECONOLINE VAN E150 4.6L V8 97-03 ECONOLINE VAN E150 4.6L V8 97-03 ECONOLINE VAN 5.4L V8 97-03 ECONOLINE VAN 5.4L V8 97-03 ECONOLINE VAN 6.8L V10 97-03 ECONOLINE VAN 6.8L V10 97-03 CLUBWAGON 6.8L V10 97-03 CLUBWAGON 6.8L V10 96-98 MUSTANG 4.6L V8 96-98 MUSTANG 4.6L V8 99-03 MUSTANG 4.6L V8 99-03 MUSTANG 4.6L V8 2001 BULLITT MUSTANG 2001 BULLITT MUSTANG 94-95 T-BIRD / COUGAR 94-95 T-BIRD / COUGAR 96-97 T-BIRD / COUGAR 96-97 T-BIRD / COUGAR The Supercharger Kit includes a new intake manifold assembly that contains an Eaton supercharger and an intercooler, a set of 30 lbs/hr fuel injectors to replace the stock 19 lbs/hr fuel injectors, a voltage step up for the fuel pump, a replacement Ford mass air flow sensor, new aluminum fuel rails, and a new electronic control module (ECM). The stock air cleaner housing is retained. The new intake manifold also acts as a mount for the throttle body, EGR valve, idle air valve bypass, and thermostat. A 180 degree thermostat which replaces the stock 195 degree is included on 1999 through 2003 applications that includes an ECM as part of the supercharger kit
EO: D-245-6 View PDF
EO Date: 1996-09-10
Manufacturer Name: BBK Performance
Device: Instacharger Supercharger
1986-1995 Ford Mustang & Capris 5.0L 1986-1991 Lincoln Mark VII 5.0L 1986-1995 Ford F-Series 5.0L 1986-1993 Ford Thunderbirds 5.0L
EO: D-246 View PDF
EO: D-271-7 View PDF
EO Date: 1996-12-24
Manufacturer Name: Kenne Bell, Inc.
Device: TS-1000 Series Supercharger
1992-1996 Lincolns with a 4.6L engine 1992-1996 Ford Thunderbirds with a 4.6L engine 1992-1995 Ford Crown Victorias with a 4.6L engine 1996 Ford Mustang with a 4.6L engine 1991-1995 Ford Explorers with a 4.0L engine 1991-1995 Ford Rangers with a 4.0L engine 1995-1996 Ford E & F Series Trucks with a 5.0L, 5.8L or 7.5L engine 1997 Ford F Series Trucks with a 4.6L engine System includes Twin Screw supercharger with 3" diameter pulley, intake manifold, fuel management booster, and a new computer chip.
EO: D-271-8 View PDF
EO Date: 1996-07-23
Manufacturer Name: Vortech Engineering, Inc.
Device: 5 & 8 PSI S Trim V-1 Gearcharger System
4FH218-010S 4FH218-018S 1996 Ford Mustang 2V 4.6L May require installation of Vortech fuel management system on the fuel return line, & supplemental fuel pump, and modifications made to the intake air ducting.
4FK218-010S 4FK218-018S 1996 Ford Mustang 4V 4.6L May require installation of Vortech fuel management system on the fuel return line, & supplemental fuel pump, and modifications made to the intake air ducting.
4FM218-010S 4FM218-018S 1996-1997 Ford F-150 4.6L May require installation of Vortech fuel management system on the fuel return line, & supplemental fuel pump, and modifications made to the intake air ducting.
4FN218-010S 4FN218-018S 1996 Ford Thunderbird/ Lincoln 4.6L May require installation of Vortech fuel management system on the fuel return line, & supplemental fuel pump, and modifications made to the intake air ducting.
EO: D-213-12 View PDF
EO Date: 1997-09-23
Device: 5 and 8 PSI. S and A Trim V-1 Gearcharger System
4FH218-010S 4FH218-018S 1996-1997 Ford Mustang 2V equipped with 4.6L engines
4FK218-010S 4FK218-018S 1996-1997 Ford Mustang 4V equipped with 4.6L engines
4FM218-010S 4FM218-018S 1996-1997 Ford F-150/ F-250/ Expedition equipped with 4.6L engines
4FM218-020S 4FM218-028S 1996-1997 Ford F-150/ F-250/ Expedition equipped with 5.4L engines
4FN218-010S 4FN218-018S 1996-1997 Ford T-Bird/ Lincoln VIII equipped with 4.6L engines
4GH218-060 4GH218-060S 4GH218-068 4GH218-068S 1994-1997 GM Camaro/ Firebird equipped with 5.7L engines
We hear such horror stories about the "Evil California", lol.
We have no rules here, basically. :)
I ran across a name that made me think of you, yesterday; A Gunn was involved in the Manhattan Project at Los Alamos in WWII, and triggered a thought. :)
@OP: the car looks like a winner! I'd pick it up if everything else is in proper order.
You have to jump through hoops to get big power to be legal here in CA.
But, as for "moving the goal posts", yea, that part sucked on my daily, lol.
And @S4gunn, you sure do research your stuff quite methodically. I love it!
Discussion Starter #26
On another note unless I had to create a new username in not sure why I’m a newbie. I’ve been researching this page since I was 15. I remember the sketch of the yellow Thunderbird that’s always looked so awesome!
Post up in the admin thread, with your original info; there's a process to recover your account.
Unless its 94badbird, lol. (That's a joke)
:rofl:
Post count, you're a 1st gear poster now! :)
The surname Gunn often denotes someone of scottish descent from the Clan Gunn. Those folks were originally vikings who liked Scotland and stayed.
https://en.wikipedia.org/wiki/Clan_Gunn
I have a necktie with their tartan but as an asian guy, yeah, they have nothing to do with me (I also could give two shits about cultural appropriation).
The few times I've heard of someone else with the first name of Gunn, besides me, the person was nordic (short for Gunter) or Indian (short for Guna or something like that). Oh, the sidekick to the John Wayne like truck driver in the ode-to-ramen japanese movie Tampopo (1985) was named Gun as well.
As far as the car is concerned -- if it wasn't such a pain in the ass to get access to the sparkplugs in this car with a 4.6L modular, I would suggest a compression test on all 8 cylinders to check the health of the engine.
That might give you a good indicator of how abused the engine has been given the injector sizing. If you do a test drive, be very observant to any pinging. If you heard it once, the owner probably heard it a lot more.
If you can get to one plug, maybe at least look at the spark plugs to see if the car has been running super lean.
Anyone ever heard of a 4.00 rear end? I’m looking at buying a 96 t bird Allen supercharged and guy is telling me the rear end tag says 4.00 and he and a bunch of gear heads are baffled. It’s a 8.8 rear end, car is really clean and can get it for $3500.
Car has a 97 Crown Vic motor and trans in it. It’s a 4.6 v8. I can’t figure out how to upload a video but from what he’s sent me car runs really good. Thoughts?
Did you end up buying this car?
This was my neighbors car. I ended up picking the car up as a cheap daily driver and am in the process of sorting it out. There was nothing major wrong with the car, the engine was out of a Crown Victoria and the transmission was sourced from a local shop after the Jasper failed. After he replaced the engine and transmission he didn't drive the car much because he was worried about the safety of the supercharger set up (fuel and timing). Now that I have it, it has a Lightning MAF, Lightning IAT in the upper intake post intercooler, FMU has removed and regulator installed back on the fuel rail, 42lb injectors on the way and a tune (base file). As for the rear end gear, I have not jacked the car up and validated what gear is installed but the door tag is a 5, and from the little research I have done indicates that it has a 3.27 installed. The odometer quit working and I need to pull the cluster and see what is going on with it.
21 - 33 of 33 Posts
