I've started to tear the engine apart...
But I just don't get how to get the "#¤&%)="¤/%"¤%&!"
fan loose?!?!?!
After an hour of swearing and coming up with even worse words than that
I checked the chilton manual...
And the [email protected] thst wrote that manual just stated
that I should loosen the four bolts that goes into the
waterpump...
That's not even connected to the fan...
Well... Took out the four on the fan...
That didn't work either...
Now there's only one heck of a nut left,
guess it's that one that holds it...
But what did you guys use to keep the pulley/waterpump
still when you loosened the nut??
Thanks in advance!
REg's
//Per A
fan loose?!?!?!
waterpump...
Thanks in advance!
REg's
//Per A
