just got a 97 cougar, up from my 93 which has quite different door panels.......anybody have a link or directions on how to take them off? i dont want to accidentally break any fasteners....
also, when you pull the drivers side door handle when locked, it makes the interior lights go on, then turn off after a few seconds.....is that normal?
Yes that's normal.
To remove the doors you need to pull the trim piece with the switches out towards you from the hinge side then slide it forward to get it off the handle. There is a screw behind here, and another in the reflector on the lower doorjam side corner, pop that off and pull the two screws then lift the door panel upwards and out.
