1 - 20 of 22 Posts
But not the normal one. :D
If the area measurement between a dual exhaust and a single exhaust is the same, will one make more power and/or torque than the other?
For example:
Dual 2.5" = 9.82 sq in total area
Single 3.5" = 9.89 sq in total area
Which one will provide the best horsepower and which will provide the best low end torque? :confused:
And why!! :D
With exhaust you are dealing with volume. A 3.5" single exhaust is going to kill your low end as it flows at a higher rate than the 2.5" exhaust does.
with respect to volume, i'm afraid you're incorrect LOLA
V=Area*Length
the volume of a pipe is the cross-sectional area multiplied by the length.....so the length of the pipe will still be pretty much the same to the rear bumper of the car.....and as 94DD pointed out, the cross-sectional area of a dual-2.5 vs a single 3.5 is pretty much identical
as far as the original question, i personally havent seen any tests between such setups.....but if you want low end torque in an mn12, you'd have to use relatively smaller pipes (<2.5") to increase the exhaust flow velocity out of the cylinder.....an X-pipe is also said to help increase some scavenging to promote better torque output overall
I suspect that the power and torque curves would be so close that there would not be a measurable difference. I think the difference in sound however would be drastic, and a single 3.5 would probably sound like crap compared to dual 2.5s.
Oh yeah, also the car with the single 3.5" exhaust would be slightly faster because it would weigh slightly less because there is only one exhaust pipe running to the back instead of 2.
V=Area*Length
Hmm... But wouldn't a dual have twice the length when added together because there are 2 pipes?
I run a single 3" on mine and the pipe is overall shorter because the pipe can be bent less severely since there is only one pipe. I'm sure the difference is minuscule at best, but just putting that out there.
think about it water being pushed thru a big pipe will run slower than the same amount of water being forced thru a smaller pipe. Just like pinching down a water hose to get the water to shoot out quicker. With exhaust uyou want good vaccum the bigger the pipe the slower the gases flow=poor vaccum. also when gases cool they become more dense and slow down due to loss of heat
think about it water being pushed thru a big pipe will run slower than the same amount of water being forced thru a smaller pipe. Just like pinching down a water hose to get the water to shoot out quicker. With exhaust you want good vacuum the bigger the pipe the slower the gases flow=poor vacuum. also when gases cool they become more dense and slow down due to loss of heat
That's the thing though, it's not the "same amount of water."
With dual 2.5" exhausts even though it is smaller, it is only passing half the volume of exhaust. (We're talking true duals here, no crossovers, x pipes, etc.) The other 2.5" pipe is handling the rest.
With the single 3.5" exhaust it is passing the exact same amount of volume as the dual 2.5" with the exact same effective area.
I lean toward the single 3.5" giving slightly more power because all the exhaust pulse waves are "inline" (assuming equal length headers), whereas in the duals, the pulses are not sequential due to the firing order.
But just my babblings, and why I asked this question. :D
Same for me. 3" was the choice for my car by a very good exhuast guy. He thought it better than duals because the single pipe is straighter. I am very happy with the results and it has lots of low end torque and a very flat torque curve. 276 lb-ft max at the wheels.
That sounds about right to me, considering the reason for the X or H pipe is to balance the pulses, and an X or H pipe makes slightly more power than true duals without it. Still though, the sound of a single 3.5 compared to dual 2.5 would be enough to make me not want it. I've heard a single 3.5 on an LS1 firebird, and it sounded awful.
I used a 2-1 resonator vs. an x or h pipe. It does have a different sound than an F-body or Stang. Personally, I like it better. My stock LS1 TA has a gurgley sound similar to the Stang. The Bird has more of a low rumble.
Just shooting from hip here, but I'd say the 3.5 single will outflow two 2.5, in equal setups (same length, same bends). My reasoning is that line loss in fluid flows result from the fluid shear present where the fluid is moving against the pipe. Does that make sense? I'm not sure if that's phrased well. Anyway, while both a single 3.5 and dual 2.5's have the same cross sectional area, the total perimeter of the 3.5 is about 11", as compared to 15" for the duals. There's more wall for the fluid flow (exhaust in this case) to rub against, more fluid shear. That's my thought anyway, but I'd like to see some testing done to provide quantitative results.
Thoughts?
Mike
deppends what your talking about as in if you put the duals on a 96 4.6 bone stock npi the duals may flow better than the 3.5". on a 200hp npi stock motor the 3.5 may result in poorer scavenging than the duals as in =less flow???? idk??/
Nowhere in my post did I say which will make more power. That is ENTIRELY application dependant. All I said was that a single 3.5 has more flow capacity than dual 2.5's.
Mike
my bad :eek: and i totally agree on that! A 3.5 single should have more flow capacity
...I'd say the 3.5 single will outflow two 2.5, in equal setups (same length, same bends). My reasoning is that line loss in fluid flows result from the fluid shear present where the fluid is moving against the pipe....
Thoughts?
Correct.
-Rod
Mike is running 3.5" single on his blown mark viii . Is there any other MN12 or FN10 car running single 3.5" out there?
David Neibert is running a mandrel bent 3.5" mid-section on his 10 second SC.
-Rod
We are running Smokymance's old set up on the SVO car.
Catless down pipes with a magnaflow midmount and a 3inch mandrel after the midmount.
The car pulls alittle harder in the upper RPM's.
Torque lost is not noticable.Hell it has an SVO M112 on it.
100% guessing. I vote 3.5" for HP and 2x2.5" for torque.
But in all actuality, I say to be able to come to any sort of conclusion.. DYNO TIME! It's just so dynamic. If the sources were equal for both setups, I'd say 3.5" too, just my thinking. But, the sources wouldn't be the same. One 2.5" would be fed by 4 cylinders... the 3.5" would be fed by eight... and even then, both setups would typically be post catalytic-converter. In any cause, unless something is horribly wrong, I'd say the differences would be almost neglible.. and would place different events at different RPMs.
The 3.5" pipe would literally flow more than two 2.5", even if the area were exactly the same, it has less wall surface to add friction to the flow. Exhaust gas or water or marbles or BBs.
Dual 2.5" would have a more pleasant note. Likely mufflers added to the systems would shift the advantage to the dual 2.5" set up as most of the available mufflers that would fit under these cars and fit a 3.5" pipe are going to be more restrictive than two simular sized mufflers with 2.5" inlets.
My old 454 Chevelle had only 2.5" pipes yup front and 1.875" tail pipes after the mufflers (which cooled the gases and thus allowed same flow of now smaller volume). It ran OK, sounded OK. The old Chrysler performance cars of the '60s which had the best sound of any car IMHO, like the 383s and 440s (and my 340 Swinger) had 2.25 head pipes (Hemi had 2.5"head pipes) and 1.875" tail pipes after the mufflers, they did OK too.
These bigger pipes many use now on street cars have a "fluffy" sound in comparison to the "sharp crackle" heard back then due to slower velocity of the gasses.
Just not a fan of oversized pipes and wheels I guess.
1 - 20 of 22 Posts
