1 - 20 of 142 Posts
shaken, not stirred
I have been reading several different websites and compiling information that was consistantly reported. If I was leary about the information I didn't use it. I originally was searching for my own purposes and realized there wasn't really a one stop place for all this information, so I decided to do something for my community. If there is any major discrepencies please let me know and I will adjust. Also I am sure there is some things I have missed or couldn't find, so I would appreciate that information as well.
Spare Tires
-Stock steel T-Bird doughnut 27lbs
-Mark 8 alluminum spare 18lbs
-Mark 8 alluminum spare WITHOUT Tyre 10lbs
Drive Shaft
-Stock T-bird/Cougar driveshaft 21.5lbs
-Mark 8 Driveshaft 14lbs
Differential
-Stock Iron T-bird/Cougar 3.27 trac lock pumpkin 80lbs
-FRPP 3.73 trac lock pumpkin 62lbs
Engines
-Explorer/Mountaineer complete aluminum 4.6 100lbs lighter
-96+ Romeo iron blocks: 154lbs, fully assembled 500lbs
-96-99 cobra / 93-98 mark 8 Teksid block: 85.40lbs, fully assembled 425lbs
-2001+ WAP block (NA Cobra) 80.40lbs
-Early cast crank = 46lbs (93 and 97 tested)
-Late cast crank = 44lbs (2002 tested)
-2V heads = 46lbs each
-4V B Heads = 60lbs each
-2V Plastic PI Intake = 12lbs
-2V Bullitt Intake = 37lbs
-Cast iron flywheel = 21lbs
-Spec Aluminum dual pattern flywheel = 12lbs
Doors
-Stock T-bird door 70lbs
-Fiberglass T-bird door 17lbs
Battery
-Stock T-Bird/Cougar 48lbs
-Optima Red Top 33lbs
-Odessey battery 12lbs
Hood
-Stock Hood 58lbs
-Fiberglass Hairyglass hood 18lbs
Trunk lid
-Stock T-bird deck lid 37lbs
-Fiberglass Hairyglass deck lid 9lbs
Lower Rear Control A-arms
-Stock A arms 27lbs (each side)
-Aluminum A arms 14lbs (each side)
Seats
-Electric Seats w/leather 56lbs
-Manual Cloth 30lbs
Engine Cradle
-Stock MN12 cradle ***lbs
-Tubular cradle ***lbs
Brake Calipers (unloaded)
-Stock Front non-sport 8.75 lbs (each side)
-Stcok Front Sport 8.3 lbs (each side)
-Stock Rear Sport and non-sport 9.2 lbs (each side)
-PBR GT Front 10.4 lbs (each side)
-Brembo Cobra R Front 8.4 lbs (each side)
Brake Rotors
-Stock Front non-sport 15.7 lbs (each side)
-Stock Front Sport 17.5 lbs (each side)
-Stock Rear Sport and non-sport 9.6 lbs (each side)
-Brembo GT Front Slotted/Vented 15 lbs (each side)
-Brembo 13” Front Slotted/Vented 18.6 lbs (each side)
C.Hill
shaken, not stirred
some of those numbers dont sound right, and the cradle is nowhere near 250, in fact the tubular one listed would weigh more than the actual stock one
Untill verified, I will take it out. Thanks.
C.Hill
Fry Rice Specialist
i believe stock mn12 angine cradle without suspension just bare cradle is about 50-60 lbs.
Are those arms an economical weight loss with the cost of those spring perches that are custom parts? I have thought about buying them though, but the cost of the spring perches seems prohibitive.
High-Mileage 4.6L Thrasher
A stock ''94-'95 model hood is 74 lbs,and the '96-'97 is 75lbs. Both measured without the hood liner.
JL
In time, I can get you the weight of the stock spring/shock combo, and the weight of the QA1 coilover combo.
I didn't realize someone was making fiberglass doors and trunk lids.
Refrigerator Raider Hater
rear lower control arms, stock and mark 8?
two piece rotors (aluminum hat)?
forged aluminum wheels?
manual steering rack (no more pump)?
removing front and rear bumpers (metal)?
Are the stock fan blades heavy?
Anyone want to venture a guess at what the whole of the dash assembly weighs? Unfortunately, I took mine out in peices with cutting tools. I should have wighed it. I would guess that it's a 100lb unit.
Also intesting to see would be fold-down vs regualr rear seats, exhaust systems, sound systems, carpets and plastic, etc.
I dont suppose anyone was diligent enough to collect all of the sound deadener and weigh it? Mine was mostly turned to dust. :(
I'm in the process of taking out all the sound deadener, by heating it up and scraping it out....I'm throwing it all into a box, and will weigh it when done.
Also, the dash is not a 100 lbs....I my self can take the dash in and out of the car myself, if it was a 100lbs, I don't think I could.
1 - 20 of 142 Posts
