Maybe its just me, but when I put the car in D when I go to take off from somewhere, like a parking spot, it seems like it takes longer to engage into gear than it used to before the jmod. BUT, my dipstick reads right at or a little above the full mark when the tranny is warm. Is the dipstick being accurate, or is this normal? It's not a very long pause, but noticable. I did add about a 1/2 qt about a month ago after I did the jmod cause it was pretty bad then. It did get better, but not great. I just thought I'd ask cause I'd rather not put too much Merc V in and screw somehing up. Thanks
Did you remember to check torque on the valve body bolts after about 2 weeks of driving? New gaskets seem to take their time squishing down to their final thickness, and a leaky valve body will do strange things, and if it loses enough pressure, will lunch your clutches.
mines doing the same thing.....its preventing me from changing my fluid...just in case
my fluid is still pink too and the tranny shifts perfectly.....well luxury like since I have no j-mod
If the VB bolts were torqued in sequence to 90 in lbs 3 times when the j-mod was done, then I wouldnt worry about that being the problem. I've done 8 so far and never had problems with any using that procedure. The delayed engagement I think is sometimes related to the TC, after my jmod it was delayed a little bit. I replaced the TC with a MK8 one and the problem went away.
Mine was delayed because the filter fell out and was sitting in the pan!
-ROb
