1 - 14 of 14 Posts
Ok a couple of weeks back i noticed that my gas mileage was dropping and that my car was throwing alot os smoke.. So I changed my spark plugs, cables, also cleaned my injectors (I paid it so they could do it), and I cleaned my k&n cone. My mileage has improved a little bit but the smoke doesn't go away. When the car is in a stop and I step normally on the gas pedal, smoke comes out, It does that every time... What can I do to get rid of the smoke????:confused:
It was before...... When I changed plugs and everything, I did the oil changed immediatelly... And there is still smoke, is the car burning oil?
i'd put money on the valve seals gone bad.
You can fool with a thicker oil but they need to be replaced eventually.
02 Explorer Pioneer
To be honest I don't think throwing any money at it would be worth it unless you perhaps just do a headswap; otherwise just keep her topped off with oil
Boom.
Yeah...I've had to deal with worn out valve seals for the last year and a half on my Cougar.
It wasn't worth it to me to get them replaced, I just kept the engine topped off with 5W-30, about a quart every 1000 miles.
i used 10W-40 and i dont burn nemore. Been loosing oil since about a year ago that way. Just decided to try 10W40 on the last change and no more smoke and no more adding oil.
My 176k motor used to do that too. If I would idle for a few minutes and punch it, blue smoke would pour out of my exhaust pipes. I switched to Valvoline MaxLife 10w-40 and after a few hundred miles it stopped doing this. My oil consumption has dropped slightly as well, down to a quart every 2000 miles.
maybe a dumb question, but....
will using 10W40 change gas mileage any? i used it once and thought that i got worse gase mileage... was that just coincidental? if so i guess i will have to try again... thanks.
seth
id like to swtich to 10w40 i really wish i had done it over the summer rather then with winter coming but what can you do....i may do an oil change when i get my paycheck in 2 weeks....with 144k on the clock....think i should use a high miledge oil still?.......when i used 5x30 vavoline max life i did notice a slight decrease in oil consumption....so i may just use that again
I too have to vouch for the Valvoline MaxLife.
My 94 with 250K miles on it smoked horribly at stoplights when I would take off. I started using MaxLife 20w-50 and most of the smoke went away. It took mine about 3 oil changes (9000 miles) to almost fully quit smoking. It still smokes when it’s hot and I’ve idled for a long while, but nothing like it used to.
Oh, and I don’t recommend 20w-50 as it’s too thick for most 4.6L applications. I use it because I have so many miles and obviously a lot of wear in the engine. So the thicker oil should “fill the gaps” a little better.
At least that’s my story and I’m sticking to it. :D
Seth,
I don't think running 10w-40 would change your mileage more than half a mile a gallon tops. I would try it again and see what happens.
I'm having the same problem. Could it be because of the 5w20 synthetic oil i'm currently using? I never noticed it before with 5w30...??? Next time i change the oil should i use 5w30 or 10w40..or maybe 10w30?..keeping in mind that here in Wisconsin things are starting to get pretty cold.
1 - 14 of 14 Posts
