You have all the cool toys.Lonnie said:Yes I have them and am in the process of wiring one to work with the 93 - 95 Mark VIIIs. I was working with Byron to get him to develope one for the Marks but it never happened prior to him selling the business. They are going to have a limited run of them soon but no support for the Marks. They don't do the 5.0 Tbirds either but some simple rewiring should fix that.
Not as much model specific as pin compatible. That data logger probably works with 89-93 Mustangs. If you have a 91-93 Thunderbird then that is basically (not exactly) like a 94-95 Mustang. In your case, you have a newer generation car so I'm sure it's not exactly like either one of those.driller said:You have all the cool toys.![]()
So they have to be model specific?
...Race Systems said:Is my vehicle currently supported?
As of 5/4/02, SnEEC currently supports all TFI ignition, SEFI and Batch Fire, Speed Density and Mass Air, 4cyl, 6cyl, and 8cyl EEC-IV equipped vehicles.
However, SnEEC must be adapted for use for a specific ECU pinout on a case-by case basis. This is accomplished by specifying vehicle year, make, model, and specific powertrain information as part of the order process.
The "off the shelf" SnEEC units support all 86-93 5.0L SEFI Mustangs and '93-'95 Speed-Density Lightnings. Adaptation for use with all other vehicles is a simple process and accomplished on a per-order per-vehicle basis.
Not likely. The Tweecer was mapped out using reverse engineering and isn't perfect in any way. If you are a A9L Mustang guy then it's pretty decent but it's support beyond that isn't all that great. Add that to the fact that Mike Glover hasn't bothered to update the software in almost two years and you have a product that is weak at best.driller said:Would the Tweecer RT be comparable as a real-time data-logger(assuming I put your tune(s) on it :diablo: )??![]()
I suppose so.MaddMartigan said:A dyno tune and a SCT chip is probably still your best bet.
It won't read Lambse and KAMREF? Aren't Lambse and KAMREF essentially STFT and LTFT just expressed slightly differently?Lonnie said:No, injector pulse and voltage only. input for WB.
They had a great write up on how LAMBSE and STFT compare and how KAMREF and LTFT compare on one of the alternate sites that is now gone. I think I copied the hole thing down, here is what they wrote up:icantdrive55 said:I think it's German Bosch lingo for stft and ltft. They are the same.
Reason I'm asking is because I'm interested in http://eecanalyzer.webhop.net To make some calculations it partially relies on fuel trims.
I wonder if this would be a good tuning tool?
