1 - 20 of 68 Posts
I know during my duration as a member here on these forums, I have often gotten into discussions with members about the performance my car might or might not be putting out. In my previous posts I have often stood behind the modifications I have done to my vehicle as being extremely helpful in increasing the fuel economy and performance of my car. Some people on these boards took issue to my personal experience and so I sought to put my Thunderbird on a dyno in order to set the record straight with quantitative measurements.
My vehicle:
1989 Thunderbird
3.8 V6 / AOD
127,000 miles
Modifications:
Air Silencer Delete
Polished Throttle Body
High Flow Catalytic Converters
Full 2.5in Exhaust with 18" Magnaflow DISO
Keep in mind all of the sensors and vacuum lines on my engine are new, as well as spark plugs, distributor cap and rotor, air filter. My fuel injectors were cleaned 1000 miles ago.
My car left the Lorain Ford plant nearly 24 years ago today (12/12/1988) with 140hp and 215 lb ft at the crank. On 12/09/2012, my Thunderbird put up these numbers on the dyno, at the wheels:
125HP and 250lb ft at the rear wheels. The gentleman at the dyno place believes its probably around 150HP and 275lb ft at the crank.
When I get my M5R2 off the floor in my garage and In the car, I'm going to try for 275 at the wheels. My fuel trim looked slightly lean during the whole run so if I got a tune it would probably help me out. What do you guys think I should do next to increase my performance? :)
Put an electric fan on it. Run 93 octane and set base timing to 14*. Maybe underdrive pulleys will work from a super coupe?
I was just thinking e-fan, great idea. Raising the timing for a run is a great idea too, I should buy a timing light and tweak it, I just have to make sure its back in specification before my next smog in January of '14. While I don't like the idea of running my accessories slower, I was trying to read that dyno sheet and analyze my fuel trims. It looks like I was slightly lean for the duration of my runs, I wonder if thats a tune issue or an injector issue. Could it be time for some 19# injectors?
Yes and yes - and no.
If you're swapping injectors, try going a bit bigger - say 24# to 30#. And you'll definately need a tune for that.
I'd start with a tune first, though.
It may be, if you're still under 80% duty cycle, a tune will take care of it.
Then again, go with what your tuner says, not me - I'm doing this from reading a book, but Real World Experience(tm) is a MUCH better thing, especially if the person with RWE has Copious Book Knowledge (CBK) :diablo:
Yeah I will have to find a guy who can do tunes on OBD-1 Fords, I have no idea where to look.
From that dyno chart it seems to me like I'm hitting some kind of performance wall for the duration of my powerband. I'm convinced there's not enough fuel making it into the engine. I really need something to get my HP level up as 125 to the wheels doesn't cut it...
Yeah, based on "the number" for our chassis that RWHP figure puts you at a tad over 143 BHP. Still pretty good for a 24 year old Essex. The stock tune actually runs on the rich side at WOT; based on those graphs it looks like you were tuning close to stoich before you went open loop, then it went a bit lean like you say. It would have been interesting to see what it would have done closer to the limiter.
Actually it hit the limiter so the RPMs were off. He had the computer registering the spark at the coil every 90* rather than every 120* like i'm pretty sure it should have been. This caused the computer to display the RPMs 25% low.
Injectors and E-fan can easily be done during a splitport swap...then you get a tune.
Thats really what I need in order to get that HP number out of the gutter. I'm happy with the torque I'm making. Just need more HP. Id definitely be asking your help if I decided to do a splitport swap on my car, it seems like there's alot to it.
So right now the restriction on my car is the computer, correct? Then my fuel injectors? Then followed by my intake manifold and heads?
Well what HP would you be happy with? A splitport swap wont change the torque numbers much. With the swap, injectors, and tune, you would be around 200 HP. There's a lot involved but its not that complicated.
I would be very happy with 200 RWHP. My manual swap and a tune will probably help the torque though.
What about a splitport swap makes it so much more powerful with no torque gains?
Keeping the AC? If not short belt it.
Yeah I am. Currently its not working because my receiver dryer leaks but I will fix that once it gets warm. AC is nice to have in CA.
In one word = Airflow
Take a look at the splitport design. Each cylinder has two intake runners, a long one to help with air velocity at low RPMs and a short one for increased air at higher RPMs.
Also, the butterfly valves closing off the short intake runners helps increase torque at lower RPMs.
-g
Discussion Starter #15
-g
I see. Its just looking like right now though my fuel system cant keep up with my current level of airflow. Or am I wrong?
Your wrong on this one. I have mostly stock fuel system parts from my singleport on my splitport and it runs fine, but you can make an argument that its maxed out.
My agree with Bay_Bird93. There are plenty of folks who run stock injectors with splitport upgrade. However, from what I've read, the stock 19# injectors used in a Mustang have a spray pattern that is optimized for the splitport intakes.
That being said, if you want to keep your existing singleport intake manifold, I have a set of six 30# injectors from an 89 Supercoupe I'm willing to let go for cheap if you want to get a tune to take advantage of these higher flow injectors (don't just swap them or you'll run waay too rich). I even have (6) o-ring/pintle injector seal kits (Standard part # SK57) to refurb the injectors before installation that I can include as well. They would plug right in and replace your existing 14# injectors.
-g
Discussion Starter #18
-g
As much as I'd like to do the split port swap, I currently don't have the time or the resources for the operation. I think the fuel injectors are a much better idea, I'd just have to find someone who does tunes.
Not bad numbers for an unloaded dyno.
Step at a time. It's VERY driveable as it is, so I'd start saving up for a QuarterHorse and a copy of Binary Editor (the QH so you CAN tune it, the BE to make it easier to talk to the QH).
After both are purchased, and a base tune if desired, install those.
With that installed, it becomes a LOT easier to adjust when you swap the injectors.
You'll also need a wideband to monitor the exhaust stream - there's some that can replace a standard O2, which means you could leave them installed all the time.
1 - 20 of 68 Posts
