i got the 01 gt transmission dropped today and started to disassemble it.
i got almost all the way torn down and found this right before i pulled the assembly out where the rear band goes. its just a little spring. in the picture, the case is upside down, so the spring is on the top side of the trans case. i did hear something fall when i took out the clutch assembly before the rear band.
also. when i removed the 1-2 accumulator, i didnt have a spring in the top half of the accumulator. i have done j-mods before and have the spring that comes out of the direct drive accumulator. am i missing something here?
other than that.....the trans looks, feels and seems ok. i dont know what would cause it to slip on the dyno. anyway, the 97 trans is goin in the car and i will rebuild the 01 gt trans when time and money allows me to..
the spring in the case is the anti clunk spring
Yes u usually pull that out on tear down, have u inspected all the clutches?
Ithought for sure this was going to be another dipstick tube plug thread :tongue:
That didn't even occur to me until you just mentioned it, but it IS funny and makes sense!
That spring is the Case to Planetary support you can see as #60 in the exploded diagram in this thread - http://forums.tccoa.com/showthread.php?t=137902.
The spring missing from the top of the 1-2 accumulator just sounds like somebody has that tranny apart before and did the j-mod wrong...
i called Alan he told me to check the direct drive drum clutches. he told me if i dont see any white writing on the clutches, they are toast. well...i dont see any writing. im sure it was slipping. its also got a good bit of play.
ill put the tranny back together and rebuild it at a later day.
Ill have to get those to you. Maybe I can tear it back down tomorrow
