1 - 14 of 14 Posts
I was trying to adjust my headlights today, and noticed the driver side was just flopping around. I pulled it out using a 9mm socket on the retainers and the adjuster for the up/down (the inner most adjuster) as well as the retainer directly above it were not in the adjuster base anymore. See pic...
So I took those two torx screws out, and tried to re-insert them into the adjuster, no luck.
So I'm assuming the adjuster is broken? Is this something I can replace at the auto parts store, or do I need to pull ones off a headlight at the junkyard (assuming I can find a good one)?
Or is it time for a new headlight assembly? They're not foggy/scratched up. I'd like to keep them if I can.
This looks different than the adjusters on my '94 T-Bird.
Auveco makes/sells automotive clips, screws, connectors, headlight adjusters, etc. Their catalog has thousands of products. If you don't have a part number, finding the part you need can be a challenge.
Disclaimer: I have no financial interest in Auveco or the other company links provided.
Good luck, man. Finding small parts can be a real PITA.
https://www.auveco.com/default.aspx
ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
Northland Fasteners- Best selection of Automotive Fasteners - 816 453 7277
That's because mine is a 97. Different headlight design, different adjusters.
I'll check it out. I was on the way to the salvage yard to see if I could scrounge some, but that was the day my oil line decided to let go.
I think I have a few spares. I'll check when I get home tonight.
  • Like
Reactions: Woodman
Here's what I've got:
I could use them, how much would you like for them?
Which parts do you want? There are more than a couple lights worth here.
Two of the longish ones with an adjuster and a secure post in them please.
Received the adjusters today, thank you very much!
Discussion Starter #14
1 - 14 of 14 Posts
