1 - 2 of 2 Posts
3rd Gear Chirper
Do they make these for MN12's? I know they make 'em for Fox cars. If I get steel ones, should I put one on each side of the motor, or just on the drivers side. I'm more concerned about durability than comfort, as long as it's not going to vibrate enough to make a CD player skip I don't care.
High-Mileage 4.6L Thrasher
I run a solid steel mount on the driver's side,and a stock mount on the pass side.It's hardly noticeable over the stock mouints on both sides..but that might change now that I have a solid rubber mount to put on the pass side when the new motor goes in.
If you want solid steel mounts-you'll have to make them yourself-nobody makes a steel MN12 engine mount,or even urethane for that matter.
JL
1 - 2 of 2 Posts
