1 - 2 of 2 Posts
hi folks
is actually somebody here who has a 4r70w behind a carburated motor??
and how is it coming around???
there is 2 ways that you can do it.
1: put 4R70W parts into a 4R70 trans with a manual valve body
2: get a electronic programmer to control the electronics in the 4R70W transmission
option 1 is the cheaper way of doing it. I had a friends dad put the trans together for me but you will need a upgraded valve body to run the newer gear set. also note this was put into a 90 grand marq so it did have fuel injection but the only electronics to the trans where for PARK switch and the Rev. lights, so should still work in a carb engine.
1 - 2 of 2 Posts
