1 - 10 of 10 Posts
the other day i went to start my car and it sounded like the starter didn't engage, and it just spun or something. I tried again and it worked fine, but every now and then it does it... Should i be worried? Here's a video (not mine) of what it sounds like. Notice how he tries to start it, but it's just a high pitched whine, then he tries again and it starts...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ufWJIVjL5QE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ufWJIVjL5QE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
The Starter does two things, spins up and engages a gear on the flywheel:
It has a solenoid that pushes the bendix against the flywheel. Otherwise you would have the little gear always on flywheel. Sounds like its time for a new starter or solenoid (IMHO just get a starter)
Other Fords, 2300cc trucks for one, are well known to wear off the teeth where the engine usually stops. The fix for those is a new flex plate.
It could easily be the starter tho. If replacing it doesn't fix it, flexplate may be the issue. Look at it while you have the starter out.
Unfortunately from the video I only hear fuel pump whine, then the car starting up. Fuel pump should run for 2 seconds KOEO. If it is intermittently not doing anything, just a small click up front, it could be the small wire on the starter that has some corrosion.
-Rob
ok, well then maybe it's not the same thing as in the video. It's not a small click up front though, it's just like an electric motor spinning freely, and the engine not turning over at all. Hopefully i have a little while before i have to replace my starter. Thanks guys.
i had a 76 nova with a missing tooth on the ring gear. i would pop the hood, grab the fan belt and pull the engine over by hand a little. it would start next try. i don't think you're gonna do that with a 4.6, though.
Im gonna say that it sounds like your bendix isnt kicking out on the starter then. This can happen intermittently. If it was only a bad spot in the flywheel, it would probably make a horrible whine/grinding sound as it tried to get the engine to turn from that spot. You can bust out a socket and turn the engine slightly to get to a "good" spot on the flywheel and then it will actually crank good if this is the problem.
-Rob
I have never had to turn the engine by hand to get it to start. I just try again and it works.
Time to visit Autodrone or one of the other big box stores for a starter. You don't want to be left in the cold on an arctic upstate NY winter night. The other option could be dirty/oxidized cables or connectors, I've seen that too. I think the box stores can test your starter for current draw, may be worth a shot.
1 - 10 of 10 Posts
