1 - 15 of 15 Posts
I was leaning toward motorcraft plugs anyone have any suggestions good or bad?
Are platinum plugs a no-no?
Trumpeter Extraordinaire
Per the 1994 Service Manual, AWSF-32C is the stock plug. Platinum plugs aren't really a "no-no," but a number of people here prefer copper plugs. Motorcraft's website has slightly different recommendations.
www.motorcraft.com
A brief discussion about the difference between platinum and copper plugs was posted here.
Motorcraft is your best choice, IMO.
Platinums are better, ONLY if you don't like to change spark plugs that often.
Otherwise, copper's are my choice.
what autozone has available....
BOSCH-PLATINUM 6241 $2.19
BOSCH-SUPER 7580 $1.09
BOSCH-PLATINUM+4 4459 $5.99
BOSCH-PLATINUM-2 4304 $3.99
AUTOLITE_DOUBLE_PLAT APP764 $3.99
AUTOLITE_PLATINUM AP764 $2.59
AUTOLITE_RESISTOR 764 $1.29
SPLITFIRE SPLIT "V" DESIGN SF10D $4.49
CHAMPION 13 $1.69
CHAMPION_DOUBLE_PLAT 7013 $4.49
CHAMPION_DOUBLE_PLAT CAN ALSO BE USED 7940 $4.49
MOTORCRAFT CAN ALSO BE USED 4122 3 MO $2.49
These below are special order though
DENSO IRIDIUM 5326 $12.99
AC-DELCO-RAPIDFIRE 8 $3.99
AC-DELCO STANDARD R42LTS $2.49
SPLITFIRE_3_PLATINUM SPLIT "V" DESIGN TP10D $19.89
CHAMPION_DOUBLE_PLAT PLATINUM POWER 3013 $2.49
MOTORCRAFT 434 $1.69
DENSO STANDARD 5033 $0.99
AC-DELCO PLATINUM 41-810 0 YR
pnyklr said:
whats the awsf what brand is that?
That's Motorcrafts designation for their plugs.
Example:
Motorcraft AWSF-32CC
I wonder if thats the same as the autozone part #
Not sure, but they should be able to cross reference them.
If your not in a hurry, just order them thru Jason at Town & Country Ford, or one of the other members here that work at a Ford Dealer.
my car is running like crap and right now I'm using the GN as a daily driver which I dont really want to do so I need them like yesterday last week
Autozones cross reference with that part # didnt work
I guess i can go with these
or the bosch coppers for $1.09
yes they do and so does advance and I just found a $25 gift cert for them :)
I bought the 764 regular ones I still have to put them in the car is running like crap I hope thats the problem but I doubt it
i put autolite platinums in my 95 4.6 and they seem to do the job nicely.
1 - 15 of 15 Posts
