13's or Mildly Broken
The car has had 2 step colder plugs in it (AWSF 12C) and when I ordered plugs, what was sent was AGSF 12FM. Have the numbers changed recently? Or was I sent the wrong plugs? And if they are wrong, can they be used without a re-tune?
Thanks
-Melon
I take it this is on the DOHC car? Is it naturally aspirated? I started typing up a comment, and then realized that I've never owned a NA Ford car.:D So unless it's supercharged or turbo'd I really don't have a lot of experience. Generally speaking, however, if you're not having detonation issues, don't worry about running a cooler plug. If your tune is on the lean side, you could try to run a cooler plug to keep from detonating, but for a street application I would go with a more conservative tune, and a plug that idles better. I know this doesn't answer the question on the plug number, but it may give some insight on the tune side of the house.
Mike
I'm not sure on the tune, and yep - it's for the DOHC car and it's still N/A :D
-Melon
So the 12FM plugs that I got are good to use then? I'd rather the tune not be off and potentially harm the car.
This is good news to me :) The weather is beautiful and I may do this tonight.
-Melon
Good cuz they are now in the car :D
I'll see how these do and maybe go with copper next time? I didn't have the 91 running long enough to judge (nor did I like changing the plugs in that) spark plugs. But changing them in the DOHC isn't so bad.
-Melon
